disable snmp traps bfd
disable snmp traps bfd session down | session-up
Description
This command disables session up/down trap reception for BFD.
Syntax Description
snmp Configure SNMP specific settings.
traps Configure SNMP Trap generation settings.
bfd BFD-specific traps.
session-down Generate trap when BFD session goes down.
session-up Generate trap when BFD session goes up.
Default
Both session-down and session-up.
Usage Guidelines
Use this command to disable trap reception for BFD session up/down.
The following command will disable trap generation for BFD session down events.
# disable snmp traps bfd session-down
This command was first available in ExtremeXOS 15.5.
Platform Availability
